An old topic but perhaps a new flavor.
I always set error in to required when connecting it to the lower left terminal on the connector pane.
By this I get rid of the so detested "(no error)" part of the control name, and it prevents you from being lazy and not connecting error in for situations where you think it's of no use, but you actually would be better off doing so. It also prevents an unconnected error thread passing through behind the icon, giving the impression that error in is connected when it's not (I've seen this once; quite a nasty bug).
In the few cases where I really don't want (or have) an error thread connected to the VI, I use a home made No Error Constant like this:
So, I would like to have this Right-click option on the error in teminal to simplify this:
A big bonus if NI makes it a constant and uses my minimalistic artwork for the icon 😉 instead of inserting an error ring with 0: no error.
/Lars-Göran
