When we use the "Allow Undefined Values" functionality of a ring control for example, this is not graphically done by allowing entry within the controls value field as one would expect - instead a new strangely placed and scaled temporary entry point pops up next to the control. This looks bad, and makes it less obvious to the users what is going on...
To illustrate:
Now, I can understand what the developers have been thinking; if we allow the input this (the proposed) way the users might think that they can write a text, like 5000 Hz in the example above...but what they really need to input is the *value* that the undefined text would be associated with.
Well, I do not think people will automatically understand this any better by putting the input outside the regular input. Optimally it should be possible to input both a text *and* the value and then that value should stay in the control this run-time (available to be selected from then on)...That might require a pop-up dialog instead. But even if you end up with todays solution of only entering the value - the <Value> input and indication afterwards should be placed within the control. That is more intuitive to the users, and will look better than todays solution.
