Rounding operations (round to nearest, round towards -inf, round towards +inf, round towards zero) always result in a whole number, so it would only be natural that the resulting output could be configured to be an integer data type, because that is often what we actually need down the wire. (See also here).
I suggest to add an output configuration page to the properties of these functions. Thanks!
(There are similar holes elsewhere, but these are different ideas (idea 1, idea 2, ...) :D)
