jlokanis
SCC login dialog needs retry
Status: New
When I start LabIVEW, it will eventually ask me to log into my SCC (I use Perforce) as part of the startup process.  Unfortunatly, LabVIEW requires that I type my password into the Perforce login dialog and then Perforce responds within 60 seconds or this will fail and I will get the following dialog:
So, if I start LabVIEW and then go off to do some other task and miss the window, I get this error.  If I then open a project, it is not linked to my SCC system and none of the SCC status indicators show up on the project items.  The only way to fix this is to close LabVIEW and reopen it.
All I am asking for here is a 'RETRY' button next to the 'OK' button so I can get a second chance at this.  It is a small thing, but it would make my life much happier...  So, please vote for this idea, even if you don't have the same problem.
Message Edited by Support on 08-10-2009 08:40 AM
-John
Certified LabVIEW Architect
1 Comment
Spectre_Dave
Active Participant
Instead of restarting just go launch the SCC configure toolselect change and enter you user name & password.
I have to configure VSS everytime I launch LabVIEW.  LabVIEW does NOT handle passwords for VSS so I get the timeout error every time.
Please fix this
Visualize the Solution
CLA
LabVIEW, LabVIEW FPGA
