Project item should apply the name's case when renaming / save as over existing file.
In the example below the existing file "THis ShOUld ChAnGE.vi" should become "This should change.vi" when saving over the file.
Instead it leaves it with the previous case.
LabVIEW behavior is consistent with OS behavior. See discussion thread for more details.
