7 | |
6 | |
2 | |
2 | |
2 |
Search waveform in LV2009
If one zero-cross point of waveform is to be searched, the search waveform.vi has a bug here. Some waveform from acquisition data may has no value=0 piont. Sometimes, one float data, e.g. 0.001 can be regarded as zero in engineering field, but this point (data) can not be gotten by using such search waveform.
Hopefully , the arithmetic can be improved or give a notice in its help in next version.
