Add a selectable and configurable "icon" view tab to the Project Explorer. Each view can be customized for fast access to whatever portion of the project you are working on at the time, and a different configured view can be selected with the drop down selector.
It would be nice to have more selection on the icons, but the existing icons with name strings from the items tab could also be used. These icons would be in place of the buttons in the following images:
Then with a simple drop down selection you would have fast access to the next items you configure for that view:
etc... etc... etc...
The view should have a setting to autosize like clusters on the Front Panel so there isn't a bunch of screen dead space unless the user turns this off. For those of us with multiple monitors we could be editing what we want very rapidly by a drop down selection, a quick sort through the pertinent items for that portion of the project, and a click on the icon.
The views should have a setting to close all VIs when selecting another view to keep from having a huge numbers of Vis that are not being edited open in the background. This setting should be per view. It is possible someone would have more than one view that tie together on larger projects to edit sub-sections of that portion of the project.
