6 | |
5 | |
2 | |
2 | |
2 |
What is wrong with this VIs diagram?
Nothing! It's a broken dependency:
It would be nice to see the difference without having to open the error dialog:
Graphics should be improved...
The normal broken arrow should have priority over the other. First fix the VI, then the dependency... Wouldn't mind two icons, one for broken VI, one for broken dependency.
Even though this Idea is older than Show a different broken arrow when the VI doesn't have errors itself. - NI Community, I'm keeping the newer idea because it has gathered more kudos.
