11 | |
11 | |
3 | |
3 | |
2 |
To make it short. If you want to distribute your software created with LabVIEW you need to include the run-time.
I suggest that the compiled installer shoud check the pre requirements to run the distributed software and
should give the possibility to download and install the pre requirements, e.g. a simple LabVIEW should check
the installed Run-Time and if the needed version isn't isntalled download and install it.
