13 | |
11 | |
3 | |
3 | |
2 |
Often I want to only adjust the size of a VI window and then save those changes before building an exe.
Adjusting the window size alone (not in the VI Properties) and then saving does not cause the changes to window size to be saved. Often I need to do something else to the VI such as move a front panel object and then move it back to invoke saving of changes including window size adjustment.
