6 | |
2 | |
2 | |
1 | |
1 |
We are logging shared variables with the citadel database via the variable logging. In some cases (reset of PC ...) citadel makes a repair of the database after restart. When having databases greater than 20-30 GB this operation takes at least one hour. During this operation the Shared Variable Engine is not responding. When using the shared variables not only for logging purpose but also for controlling options and visualizations on that same pc this is very critical - this stops also the production for one hour.
It will be better to activate the Shared Variable Engine although during the repairing process of the database. We could pass on the data during the logging process but not on the controlling part of that aggregate.
Best Regards,
Joachim
