13 | |
11 | |
3 | |
3 | |
2 |
Installer needs option to conditionally install files.
In some installs, like a new install, the installer should install a file but that same file should not be overwriten on an update. For example, a database file that is updated by the user will be overwriten by the installer.
The options required are:
InstallShield should be consulted for the various options required.
