| User | Kudos |
| 17 | |
| 6 | |
| 5 | |
| 4 | |
| 2 |
Viewing this suggestion requires a bit of setup
Is it True or False?
My opinion is that the gradient and lighter shade of green makes the state a little ambiguous. Not too much ambiguity, but enough to give me pause. Decreasing the gradient and darking the shade a little should help.
Yes, I realize this is a property you can set. This is more of a suggestion for setting the standard.
(this suggestion aside, my compliments to the designer of the Silver controls)
