6 | |
6 | |
3 | |
2 | |
2 |
I have a Red-Green colorblind coworker. When he looks at the Silver Error Cluster, he actually cannot tell if there is an error. Why? Because NI decided to make green the false state and red the true state of the boolean. So he updates his error clusters to use black for the false state.
Simply put, that boolean display needs either icons (like in the Modern Error Cluster) or different colors to help these people.
