| User | Kudos |
| 17 | |
| 6 | |
| 5 | |
| 4 | |
| 2 |
Make an alternative Error indicator that is a tri-state LED. Green for good, Yellow for warnings, and Red for errors. And make it so you can still right click and select "Explain Warning/Error"
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
