| User | Kudos |
| 12 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
Many programming languages IDE are able to distinguish the cluster level. However, selecting a cluster element in LabVIEW requires covering the full path from the top cluster until the desired element. The consumed time for this actions is directly proportional to the cluster size. It would be great that the bundle\unbundle nodes distinguish the cluster level in LabVIEW to speed up the cluster item selection.
Currently, a selection of an item requires a full navigation:
With the improvement a selection would only require partial navigation:
