It would be nice if we had the ability, without selecting and dragging, to quickly copy repetetive items between:
a. From a Front Panel to different a point on the same Front Panel
b. From a Block Diagram to a different point on the same Block diagram
c. From a Front Panel to another Front Panel
d. From a Block Diagram to another Block Diagram
1. Left click an item to select it, not it's label, in any open Front Panel or Block Diagram
2. Find the place in the desired point in a Front Panel or Block Diagram for the duplicate to be laid down
2. Hold down the spacebar (Ctrl, or any other assignable key)
3. Left click the mouse to drop the duplicate item
