| User | Kudos |
| 11 | |
| 10 | |
| 7 | |
| 5 | |
| 4 |
Now I come up with a thing I requested 2003....
I would like have a statusbar for some UI. This line attached to bottom of the window, to show up status informations no matter where the user scrolled the frontpanel.
The picture should give a coarse impression (I didn't invest a lot time in editing the picture....)
I think it can already be done with activeX , a bad workaround is moving some indicators with properties (performance with overlayed indicators and flicker)
Currently you only have the titelbar...
I would like to show things like current test runtime, active comports, warnings etc...
