| User | Kudos |
| 5 | |
| 3 | |
| 2 | |
| 2 | |
| 2 |
In most of the cases, front panel is not use for a subVI, but it always disturbs me be opening too many windows. So, there should be a new kind of VI that only have a block diagram. Terminals could be designated on the block diagram.
