There should be some way to name splitters and panes on the FP. It's annoying that they are just generically named, e.g. "Splitter 2" or "Pane 3". Especially when, over the course of development, you add more in between existing ones....often I've been confused by the fact I have 3 horizontal splitters that are numbered 1, 3, 2 from top to bottom.
Same thing with the panes they separate. I want to be able to refer to the "graph" pane and the "toolbar" pane, etc. And see the associated references, property/invoke nodes use that same nomenclature for clarity on the BD.
