13 | |
11 | |
3 | |
3 | |
3 |
LabVIEW's HTTP Request client currently does not support the PATCH method. This method is becoming increasingly more popular within RESTful API's and has been an officially recognized verb since 2010 (RFC 5789). It should be fairly simple to integrate, since LabVIEW runs cURL under the hood and cURL implements it with curl --request PATCH
