| User | Kudos |
| 11 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
There are critical actions in the project explorer that cannot be undone (the Undo menu item is there, but it does not get enabled).
Do some intended changes without saving afterwards, then accidently delete something - and you have no way back other than to start all over.
