JackDunaway
Support Unicode
Status: Completed
Available in LabVIEW NXG 1.0. Front panel controls and indicators can now properly display Unicode characters.
Support unicode officially for all FP indicators and controls! Captions and string indicators can be "coaxed" into showing Unicode characters (among other controls/indicators), but trees and listboxes (among most others) cannot show Unicode.
Of course, this may have a small audience, but anyone who has developed a UI meant to be distributed to half a dozen language-speakers has probably fought the same Unicode battles and figured out the display "hacks" that we have.
undefined
45 Comments
ImreSzebelledi
Unfortuantely the two language don't use the same codepage as for one operator it is hungarian and for an other it should be ukrainian. Windows used to have mode for starting an application in a certain locale but it is gone and it is not much of a help either becuase as you have stated it is just a pain when you store data using a certain codepage and it is just garbage when you switch to an other one. I have always thought that localisation is a really weak point of labview but damn it is just so frustrating, especially when NI just does not seem to care if you look at the date this idea was born. Saying "it is done" is the same thing as saying "it is done just because a completely other software supports it".
randol
http://utf8everywhere.org/
Please pass that link on to the NI engineers.  This is really not that hard of a problem to solve unless your source code is a complete mess.
wiebe@CARYA
Knight of NI
In stead of applocale you can try Locale Emulator (SourceForge). It probably has more options as well... I can't vouge for it, haven't used it (or forgot I did).
There are some initiatives to get threads like this to be 'uncompleted'. Not sure why this one isn't reset, it might simply take some time.
I'm do know Unicode is a priority.
Cepera
My main need for Unicode is to be able to localize the UI - all of the UI, including graph labels, string controls, indicators that are parts of (nested) cluster controls,  decorations, etc. This means not just Unicode support, but also the ability to easily load a language from some table or XML file, or something similar (not necessarily on-the-fly: restarting the program after changing language selection is not a big deal). Our company has sold instruments 70+ countries, and not everyone is comfortable enough with the UI all in English.
Additionally, I would like to have support of user inputs, including filenames. String constants on BD are also needed. Rudimentary string processing would be nice to have (along the lines of "find/replace a substring"), although I don’t see an immediate need for it. I don't need UTF-8 support of SCPI over VISA.
wiebe@CARYA
Knight of NI
You can make localized UIs with the ancient code pages system LabVIEW uses. It is in fact the entire purpose of the ancient code page system.
You'd need Unicode to support all characters at once, but I've done a few applications that support English, Cech and Chinese. If the LabVIEW application is started on a machine with the correct code page, it will support the correct characters.
Full Unicode support would help a lot of course.
