8 | |
6 | |
4 | |
3 | |
2 |
The signal processing VIs only tend to support DBL waveforms and waveform arrays. Since waveforms can themselves support many data types, the signal processing VIs should also be able to adapt to non DBL based waveform data. EXT at the very least.
