6 | |
6 | |
3 | |
2 | |
2 |
Hello all,
I have a suggestion about Automotive Diagnostic Command Set. It is currently designed for CAN-based diagnostics only and diagnostics on serial lines (K-line and L-line) are not in the scope of the Automotive Diagnostic Command Set.
I would like the Automotive Diagnostic Command Set to support diagnostics on serial lines (K-line and L-line) too.
Automotive Diagnostic Command Set User Manual
http://www.ni.com/pdf/manuals/372139a.pdf
Best regards
Rutsu Kenmoku
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
