6 | |
6 | |
3 | |
2 | |
2 |
(hope this hasn't been posted before, couldn't find it)
Since we now have 64 bit numbers, can we please have a Swap Long function?
This is a real hassle to do yourself (convert to byte array, rotate array, convert back? or flatten to string, flatten back with different byte order?). If you have large arrays of "quads", it is a real performance hit without the function.
Wiebe.
