I like system controls.
In fact, if the system control set could be augmented to include cluster/array frames, graphs and some decent boolean indicators, then I would probably create an idea to ditch the modern controls entirely!
But I digress...
One very odd thing that happens when you set the system control set as your default is that every time you create a boolean control/indicator from the BD, you get a radio button! That's never what I want!! Are there any use cases where it makes sense to create a single radio button from an existing BD terminal or wire?? I'm guessing that the radio button is replaced with another control in 99% of cases.
I propose that the default boolean be changed to a checkbox.
This is obviously not going to satisfy all use cases but a checkbox makes much more sense than a radio button:
This is a small but significant improvement that could surely be made very easily.
This has been mentioned before as an example within this idea, but I think it deserves to be evaluated on its own.
