oenk
Unit Test Framework: add categories and or UT selector
Status: Declined
It would be nice if UnitTests could be grouped into categories, so only a subset of UnitTests can be run (like it is in Visual Studio 2010) at any time. Or if the UTs are displayed in a list and one can choose which to run.
As you can see in the snippet I've got 4 UTs two read and two write. Those are grouped into tests for DeviceUnderTest 1 and DUT2. Now I can run UTs for e.g only DUT2 (as this is the one currently connected to my hardware). Or I can run only the read UTs and so on...
I know: normally you run all UTs but during development it might be nice to run only a subset of them...
4 Comments
oenk
Here the image in full size...
AristosQueue (NI)
NI Employee (retired)
Oenk: I have only used the UTF a few times, but I thought you could group tests using virtual folders in the project and then just run that folder. I really don't remember and don't have UTF installed at the moment to try this, but you might check and see if that works.
oenk
AQ you are right. I should have looked closer to the UTF functionalities.
Nevertheless I think it would be a good idea to have some sort of grouping functionality (more than one, as a file could be only in one folder) and maybe even a GUI which lets you decide which UTs to run.
Darren
Proven Zealot
Status changed to: Declined
