6 | |
6 | |
3 | |
2 | |
2 |
Currently (up through LV2010) the only run-time menu (RTM) available for a tab control is for the entire tab control, not for the individual pages (tabs). The right-click context menu (Description and Tip, Help, etc.) for each page only works at design time, not at run time. This is true of both the default or a custom RTM.
Why is it called a "run-time menu" if it doesn't work at run time? I consider this a bug, but it probably is just an oversight in the design. (I suppose that technically this is not a "bug" because I cannot find this feature, an RTM for each tab or page, documented.)
Anyone else think this a useful product improvement?
Ed S.
