13 | |
11 | |
3 | |
3 | |
3 |
Idea: The In Range and Coerce Include upper limit option should be selected by default.
Maybe it's just me, but when using the In Range and Coerce node I virtually always need to have both the Include lower limit and Include upper limit options selected. In approximately ten years of using the node I think I used a different configuration less than five times. It has entered my muscle memory that the first thing I do after dropping the In Range and Coerce node is to right-click it and select Include upper limit.
In my experience this point of view is supported by anecdotal evidence. For example, I have recently seen a large codebase that was rightfully using lots of In Range and Coerce instances. All of the nodes had been left in their default configuration (Include lower limit selected, Include upper limit unselected). However, after inspecting the code carefully I came to the conclusion that the intention was for all of the nodes to perform an inclusive comparison on both sides. This was confirmed by a conversation with the original code author. The author had simply been unaware of the true behaviour of the node (he had assumed it performs inclusive comparison on both ends) and was unaware of the right-click options!
