6 | |
6 | |
3 | |
2 | |
2 |
Currently the default front panel Alignment Grid Size is 12 pixels. It should be 10 pixels.
There is probably a reason why 12 pixels was selected many years ago, but is that reason still valid? Twelve pixels seems like an arbitrary number. Ten pixels would be more logical because is aligned with the decimal system.
