Say I have some inputs/outputs that are shared between a function block in the start of code block and a function block that is 15 code blocks away in the LV Code.. And there are multiple such sharings occuring, without an involvement of a tunnel.. Now there are wires everywhere.. Either we cluster them into one single line (which becomes uneasy sometimes) or some use local variables (when shared and updated at multiple locations it becomes dangerous)..
Instead, if we can go wireless..
Like a transmitter at the source and single or multiple recievers at the required spots..
When there is a tunnel to be placed..
The appearance and the presentability of this method can be made much better.. (like tiny dots or something similar to bundly by name but not these ugly circles.. ) Just wanted to convey the idea.. This can remove wires flowing unnecessarily and would make the code more readable and easy to modify..
