| User | Kudos |
| 12 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
The In Place Element (IPE) is great and so are Data Value References (DVRs).... but... well sometimes I'm not such a great programmer and I will cause a dead lock in my code causing what looks like a "hang". Debugging can be hard in that case when trying to figure out which vi was trying to access the DVR. Also if I'm using the dvr for some sort of global storage, i may want an error to ocurr if some piece of code holds onto the DVR lock for too long.
I'd love for the IPE to have a timeout when you have 1 or more DVRs and if ALL of the references are not available in the specified time, the structure returns an error.
