4 | |
4 | |
3 | |
3 | |
3 |
On downloading a file from internet and if the file already exists (file with the same name), it automatically appends an auto-incrementing number to the file name, wouldn't be it nice to have the similar feature (may be optional) with Open/Create/Replace File Function.
Consider the scenario, you've enabled this option ('append number if file already exists' as shown in above figure) while using Open/Create/Replace File Function and operation input is 'create' and name of the file is MyFile.txt, which already exists then this fuction should create a new file with name MyFile (1).txt (or may be MyFile (2).txt if MyFile (1).txt also exists and so on).
Available in LabVIEW 2015 and later with the 'Create File with Incrementing Suffix' VI.
