13 | |
8 | |
3 | |
3 | |
3 |
There are a plethora of timestamp formats used by various operating systems and applications. The 1588 internet time protocol itself lists several. Windows is different from various flavors of Linux, and Excel is very different from about all of them. Then there are the details of daylight savings time, leap years, etc. LabVIEW contains all the tools to convert from one of these formats to another, but getting it right can be difficult. I propose a simple primitive to do this conversion. It would need to be polymorphic to handle the different data types that timestamps can take. This should only handle numeric data types, such as the numeric Excel timestamp (a double) or a Linux timestamp (an integer). Text-based timestamps are already handled fairly well. Inputs would be timestamp, input format type, output format type, and error. Outputs would be resultant format and error.
