| User | Kudos |
| 13 | |
| 11 | |
| 6 | |
| 6 | |
| 4 |
Having read THIS thread I realised that nearly the only time I ever use a sequence structure is to time code.
Then I thought, why shouldn't the Sequence structure have a timing output node (selectable) so that we don't have to manually do this every time we want to test code speed.
Then I thought a bit further and thought, why not have this for ALL structures, it's such a useful tool, it could be used for For loops and while lops too.
Shane.
