| User | Kudos |
| 10 | |
| 6 | |
| 5 | |
| 3 | |
| 2 |
VIMs are awesome but when wire inputs are broken they aren't awesome. They'd be awesomer if there was a way to specify that when specific frames of type specialization structures are active, there is a way to get specific strings added to the error info for the caller. Having a way to add custom strings to VIMs would overcome the general "An unsupported data type is wired to this subVI node." error string we're currently given. This can also help differentiate between LabVIEW breaking during type prop for odd (bug) reasons and properly invalid inputs... Do I need to just delete a wire and re-wire the input or do I need to hope the developer provided good VI documentation?
With some additional frames in Type Specialization Structures and maybe something like a subdiagram label but instead it could be a error reporting field at the bottom of a frame, it would be much easier to provide meaningful information back to a developer such as "GUID input only accepts GUID.ctl or a String". Then if the caller breaks with the unsupported data type error for the VIM, error details from the currently active TSSs can be concatenated to the Details string displayed in the Error list dialog. Alternatively, each error message found in TSSs could be separately listed in the Error list.
My 10 second idea:
Resulting in the Error list perhaps showing it as either an error or concatenated into the Details:
