6 | |
6 | |
3 | |
2 | |
2 |
It would be nice if the programmer could rearrange the variable names in the unbundle by name by dragging and dropping the variable names in the order you won't when your assigning the values from the block diagram. This should not affect the actual cluster order. I hope this makes sense.
