| User | Kudos |
| 14 | |
| 2 | |
| 1 | |
| 1 | |
| 1 |
I spend time making the size of my front panel and block diagrams fit my code well. Unfortunately everyone once in a while I will hit ctrl+T when I'm trying to press ctrl+R to run my code, and it of course changes the dimensions of my windows. I try to undo the operation, but it does not work properly (or as I would want it to). It moves it back to its position, but the dimensions are all wrong still. Very frustrating.
I propose that Undo reverts the panels to their pre-tiling size.
