| User | Kudos |
| 4 | |
| 3 | |
| 3 | |
| 3 | |
| 2 |
I would like the VI icon to be the icon which shows up in the file browser instead of the default LabVIEW VI or control icon. There should probably be a switch to turn this on and off, since I can see the utility of having a specific icon for VIs, controls, etc., but in normal use, the VI icon would work much better.
