Many of my projects are video inspections with the captured images streamed to an .avi file. With increase use of digital cameras with non-standard frames/sec (fps) or position-based image captures where the fps rate is determined in the field, the fps often cannot be set properly before the images stream is captured. Unfortunately, the fps value can only be set when the original .avi file is created (IMAQ AVI Create) and cannot be changed once set. There are utilities that can change the fps of a .avi file but so far I have not found easily callable exterior routine to perform the change
My simple suggestion is to either allow the fps to be set when the file is closed (IMAQ AVI Close) or better yet create a vi that would allow to change fps value for an existing .avi file
