| User | Kudos |
| 4 | |
| 3 | |
| 2 | |
| 2 | |
| 2 |
hello forum
what do you think about a "feature" where developers can enforce version control on applications deployed into end-user systems? it may sound something like some feature of a certain OS, but it may be beneficial in a way or two...
the most obvious being for version enforcement, some members may not like this, but often time newer versions of application are developed to address certain issues of the previous version, and it would be pointless if the end user kept sticking to the old version for certain feature they may have grown to like
it can also be extended to subscription based or trial version deployments, a more friendly way for developers to present their systems for customers for in-situ system trial
one way to deploy this feature, is to minimally trace the execution instances of the RTE in deployed systems, across newer and older version, log them for follow-up actions, that can range from friendly popup reminders for update to application execution prevention.
what do you think?
