Currently, the version of the packed project library (PPL, extension .lvlibp) is defined by the build script which creates the lvlibp.
It would be nice to have an option there to "hook" the version of the lvlibp to the version of the lvlib, which is used for the PPL.
The advantage is to match the developement version of the lvlib to the deployed version, the PPL.
