8 | |
6 | |
4 | |
4 | |
4 |
Probes are so useful for debugging, but monitoring them within the Probe Watch window can be a headache. I constantly find myself focusing back and fourth between Probe Watch and the code to translate a probe number to a position in the code. A solution would be to have the probe's value float just above the probe itself. LabVIEW already has a similar feature. When you use Highligh Execution wire paths display their current vaules, but using Highlight Execution is too slow and no practical for every debug situation.
Here is the issue as it stands today:
Here is my proposed new feature! :
