8 | |
6 | |
4 | |
3 | |
2 |
Hi, my customer is using cursors on his waveform graph and he has the cursor name displays enabled so that the cursor name is displayed next to the cursor.
The customer wishes to change the font for this cursor name text but I believe there is no property that can allow this.
The 3D graph seems to be able to do this but it would be great if waveform graphs can do it too.
For now, I plan to suggest the work around of placing a transparent background string indicator on his front panel and code it so that it follows the cursor.
LabVIEW 2011
Thanks!
Taiki Hoshi
AE NI Japan
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
