Hi
Quick drop is very uselful tool. When using Quick drop in front panel . A mix of different style listed .
To maintain consistent style would be better to select the style to be appered on the qucik drop. Might be useful
Add quick drop setting in the option to configure style. Though theres an option to add that in shortcuts.( thinking of adding all the items in shortcut is impossible)
