I am submitting this request based on a recent suggestion from a customer.
After doing a peak detect, the customer wants to find full width at half maximum(FWHM) of those peaks.
However, in order to calculate FWHM, information of quadratic fit used to find the peaks is needed. However, we cannot get the equation from Peak Detector.vi. This means, the user needs to do an additional quadratic fit, and then calcualte FWHM after that.
It would be very nice if we can get FWHM from the Peak Detector.vi.
Declined for reasons listed here: http://forums.ni.com/t5/LabVIEW-Idea-Exchange/easily-calculating-FWHM-from-the-result-of-Peak-Detect...
