OK...so anyone who has ever deployed a web service (not published) on a real-time system has run into this. When deploying, EVERY web service VI front panel opens on the development computer. EVERY ONE!!! Leading to an environment that becomes very unwieldly:
Is there a legitimate reason for this behavior? When I am attempting to debug an application that may use web services, I don't want every front panel to open. And, it is not reasonable to expect users to cram all web service functionality into a few VIs simply to reduce the number of windows. Can we please be given the option to NOT open all front panels when we are debuggin??
