13 | |
11 | |
3 | |
3 | |
3 |
This idea started when I realized the WebDAV API provided by NI does not have the ability to read the File Creation information on a remote file.
"That's okay" I thought, I'm a programmer and will add it myself. Looking at the source it looks like NI just leveraged someone else's protocol, and wrapped it into some Call Library Function Nodes. NI could have written the WebDAV API wrapping their own HTTP API functions, using G instead, allowing for customization but they didn't.
"That's okay" I thought, I'm a programmer, and I'll look into recreating the WebDAV API, by calling the NI HTTP API. Looking at the source sounds like NI didn't implement all of the HTTP functions available, only the most basic ones. And since WebDAV requires more than just the PUT, GET, and POST, that means also having to update the HTTP API to have those functions, so that I can rewrite the WebDAV API. Oh but look at that, NI also just (seemingly) wrapped someone else's implementation again into Call Library Function Nodes, this time calling the ni_httpClient.dll. NI could have written the HTTP API wrapping their own TCP primitive API functions using G instead, allowing for customization but they didn't.
So this idea is for one or more of the following things, from the easiest, to the most difficult.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
