Comparing VIs which have closed front panels is (almost) never used. Therefore it should not be the default.
The Dialog for selecting a VI shows all VIs in memory when first opened. There is a checkbox to "Only show objects with open front panels". It is not checked by default. I suggest to set its default value to true (=checked).
Comparing VIs is started in "Tools" -> "Compare" -> "Compare VIs...". In the new dialogue, click on "Select..." (for any of the two VIs). The check box labeled "Only show objects with open front panels" is located near the bottom.
The (write protected) VI of this dialog is at <vi.lib>\Utility\allVIsInMemory.llb\VIMemory Select a VI.vi
The calling VI is at <LabVIEW dir>\project\_procmpvis.llb\CMP Compare VIs.vi
No idea where else "VIMemory Select a VI.vi" is called.
